Spatialrelator predicate "Requestor Overlaps Supplier" and multipart polygons
  • Dec 12, 2020 6:17 AM UTC
  • 52 views
mario_bla
Participant
Hello!
How to handle multipart polygons in Spatialrelator when "Support all predicates" is checked (because they are not supported with this Support mode). For example I have district with islands and I want to check if it belongs only to one higher level district (or it overlaps more then one higher level districts).
@mario_bla​ Could you use Deaggregator do the spatial relation and the Aggregator to rebuild you multipart areas with a list of the associated districts.?
If you attach a small example dataset it might be possible to create an example workspace
