Snapping in 3D
  • Jun 29, 2022 7:32 PM UTC
  • 161 views
ienesaglam60
Forum|alt.badge.img+3
screenshotsI have a polygon and two lines inside.
The Lines z is true elevation and lines snapped to area in 2d.
I want it to generate points at intersection points and snap 3d to lines like in the figure.
The sample data (dgn) is attached.
kailinatsafe
Forum|alt.badge.img+24
Hello @ienesaglam60​ , there isn't a great way to 3D snap in FME as of yet. It looks like there is some speculation around adding it - no adopted timeline however (FMEENGINE-15050). It might be worth upvoting this idea on the Knowledge Base, if this is something you'd like to see added to FME.
Otherwise, there are many ways you could appraoch this, maybe be deaggrating the lines or use a Intersector to create the nodes at each line? Once you have the nodes, maybe you could use node coordinates to build the line or 3DInterpolator? Alternatively, the Chopper could be a fairly useful transformer for this challenge. Happy to help, Kailin.
