Shape export problem
connecter
Forum|alt.badge.img+10
I export a shapefile from FME. The shapefile contains lines and some entries without lines. After that I open it in QGIS. The shapefile looks good, but then I try to edit some specific lines I get an error:
CRITICAL   Layer Info : OGR[3] Fehler 1: REPACK of layer 'Info' failed.
I try to find a solution for the problem and find a workaround:
  • Export the same shapefile again in QGIS to shp
    • All data inside are the same, only when I try to open it, the header is different
      • QGIS writes "ƒpè": QGIS_shp_Header
      • FME writes ƒè: FME_shp_Header
    • When I copy the three characters from QGIS manuell it works! Why? What do these characters mean?
What can I do to get the same output like QGIS?
Sry I can´t share the workflow and the data-> workstuff.
Thanks for your help. 😃
virtualcitymatt
Forum|alt.badge.img+43
Check the encoding setting on the shapefile writer in FME. By default it will use your systems encoding. Try setting the encoding to UTF-8
connecter
  • October 20, 2020
Hi @virtualcitymatt​, thanks for your reply. I try the setting without success. :(
I also try other geometry outputs.
