I'm working on a system which has Oracle Client 32Bit and 64Bit installed. The environment variable for ORACLE_HOME points to the 64Bit version. I need FME to use the 32Bit Version of the Oracle Client - just for this very FME process. Is it possible to set the environment variable temporarily at runtime (e.g. Phytin Startup Script)? How would this be done?
