Send a e-mail when change between 2 set fo data
  • May 27, 2021 2:22 PM UTC
  • 25 views
hugues
Hi, I have to check 2 set of data. The source is a xlsx files and the replication is a Acces files. I would to compare the 2 set of data and send a e-mail if it's have some change beetween the 2 set fo data.
Thank you for the help.
philippeb
Forum|alt.badge.img+23
  • May 27, 2021 2:32 PM UTC
Use the ChangeDetector.
Plug the Emailer to it.
Add a DuplicateFIlter or a Sampler between the two if you don't want to have too many mails.
