Select Records in single table and add value to other field
  • Dec 1, 2022 8:06 PM UTC
  • 109 views
vxn43
Forum|alt.badge.img+20
I have a single table, TABLE1. I have a field named STE. I would like to select the values of STE that are NOT NULL, then add the selected values in STE to the ADDR field in same table.
What is the most suitable transformer(s) to go about doing this?
Best answer by dustin
Several ways to accomplish, but I normally use an AttributeManager with a conditional value. The test condition will be testing SDE for not null, if so, set the attribute value to SDE. Otherwise, no action.
dustin
Forum|alt.badge.img+36
  • Dec 1, 2022 8:42 PM UTC
