Select Linestrings from a PostGis table usingg SQL executor.
  • Nov 2, 2020 10:42 AM UTC
  • 64 views
pschout
Forum|alt.badge.img+7
I use the SQL executor to join a lot of PostGreSQL and PostGis tabels.
One of these tables contain a "geom" column with points and line objects. At the end of the SQL statement i want to select only the lines. Can anyone specify which statement to use to select only linestrings?
Best answer by ebygomm
I don't have access to PostGIS to test but something along the lines of ?
where ST_GeometryType(geom) = 'ST_LineString'
Forum|alt.badge.img+54
  • Nov 2, 2020 11:07 AM UTC
bwn
Forum|alt.badge.img+26
  • Nov 2, 2020 11:15 AM UTC
Yes, this ^^^.   Also alternative PostGIS function supported is:
WHERE GeometryType(geom)='LINESTRING'
See PostGIS Documentation
https://postgis.net/docs/ST_GeometryType.html
https://postgis.net/docs/GeometryType.html
pschout
  • Nov 2, 2020 11:36 AM UTC
Thanks! Both options are useable!
