Save Parameters for use in other workbenches
  • Sep 10, 2023 4:04 PM UTC
  • 8 replies
  • 303 views
ingalla
Forum|alt.badge.img+10
Hello
Is it possible to create user parameters and save them for use in other workbenches?
I have numerous workbenches that all load different data however some of the parameters will be the same and used in every workbench.
I have looked at the documentation, but cant see anything obvious. If these created parameters could be saved to either a database, or file to allow sharing with others that would be even better...
Regards
Andy
Best answer by matt.m-at-safe
@ingalla​ If you have FME Flow 2023+ in addition to FME Workbench 2023+, you can use deployment parameters. Deployment parameters are stored centrally on FME Flow and can be referenced across many workspaces. Please see Getting Started with Deployment Parameters to learn more.
Forum|alt.badge.img+63
You can create a template workspace with all those user parameters, but otherwise empty, then use that as a starting point for any new workspace you're going to develop.
joepk
Forum|alt.badge.img+22
  • Sep 11, 2023 12:25 PM UTC
You could look into using something like a CSV or an Excel file to store your parameters. Then if you want to use the parameters you can fetch them using a Reader and store them in an attribute.
ingalla
  • Sep 16, 2023 6:29 AM UTC
Thanks both for the responses - i guess what i am after is a database. I could potentially have over 100 workspaces, therefore if the values in the parameter needed to change, i only wanted to change it once and it would then show across all workspaces using that parameter...going to have to think about this one.
Thanks again
matt.m-at-safe
Forum|alt.badge.img+14
ingalla
  • Sep 20, 2023 10:20 PM UTC
@mattmatsafe​ that is perfect, absolutely what I was after, just the smallest request, could the icon stay green and not change back to pink in desktop to save confusion and differentiate the parameter types
matt.m-at-safe
Great!
For the most part, the icon should remain green, however, I do see that if a deployment parameter is used as a Rule Configuration value in an Attribute Validator, or in other cases where the control is an inline drop-down list, it does not. I have created an internal ticket for that to be addressed in a future version (ID FMEFORM-29466).
ingalla
  • Sep 21, 2023 7:14 PM UTC
Great!
@mattmatsafe​ where are these deployment parameters stored? and is there a way to export them to share them with other authorities? I checked the docs but cant see anything???
matt.m-at-safe
Great!
@ingalla​ they are stored in FME Flow in the Deployment Parameter Store.
You can export and import them into different FME Flow instances by creating an FME Flow Project using the web UI.
For database and web connection deployment parameters, you'd need to include the connections as well, since the deployment parameter value just points to the name of the connection to use. But for text deployment parameters, this isn't necessary.
