Run multiple testers and update a field
  • Mar 22, 2023 8:03 PM UTC
  • 87 views
hwilson
Forum|alt.badge.img+4
Hello, I have a dataset in excel that I would like to simplify the data into a newly created status field. For example all records that are 1000 will be status A, all records that are 2000 will be status B, all records that are 3000 will be status C. I will then import the data into GIS to symbolize based on status. I am creating testers for each status type and then joining it all back together. I was wondering if there was a single transformer that I could put in all my criteria and have the status field updated. I think this should be fairly simple but not finding the right transformer. Thank you
Best answer by tomfriedl
You can use the AttributeValueMapper​
tomfriedl
Forum|alt.badge.img+14
  • Mar 22, 2023 10:12 PM UTC
hwilson
  • Mar 22, 2023 10:46 PM UTC
Thank you, that is exactly what I was looking for.
