Rows in Columns
  • Jun 29, 2023 6:33 PM UTC
  • 16 replies
  • 116 views
asadamjad
Participant
Forum|alt.badge.img+12
As you can see, when I extract the data, it's showing me all "advrnum" with "td".Screenshot 2023-06-29 at 11.31.10 PM
but when I merger them so I get only one recoder of Advr 8
I need all rows.
Screenshot 2023-06-29 at 11.33.29 PMScreenshot 2023-06-29 at 11.32.50 PM
danilo_fme
Forum|alt.badge.img+58
  • Jun 29, 2023 8:44 PM UTC
Hi @asadamjad​ , COuld you share your data?
asadamjad
Participant
  • Participant
  • Jun 30, 2023 12:11 AM UTC
https://www.nhc.noaa.gov/CurrentStorms.json
check mostLikelyTimeTSWindsGIS
O ad 1
Forum|alt.badge.img+63
Can you give us a bit more information about what you want to achieve here?
asadamjad
Participant
  • Participant
  • Jun 30, 2023 11:15 AM UTC
i dont wanna merge at the moment its merging popupinfo
asadamjad
Participant
  • Participant
  • Jul 6, 2023 7:19 PM UTC
anyone
geomancer
Forum|alt.badge.img+69
  • Jul 7, 2023 11:52 AM UTC
So don't merge?
It is very hard to help you when you give such scant information. What are you trying to achieve here?
By the way, at this moment CurrentStorms.json does not contain any storms.
asadamjad
Participant
  • Participant
  • Jul 13, 2023 8:19 AM UTC
now you can try
geomancer
  • Jul 13, 2023 9:00 AM UTC
Yes, there is one current storm mentioned now.
So what are you trying to accomplish, and what problems do you encounter?
asadamjad
Participant
  • Participant
  • Jul 13, 2023 9:15 AM UTC
geomancer
  • Jul 13, 2023 9:27 AM UTC
Expose the attribute mostLikelyTimeTSWindsGIS.kmzFile in the JSONFragmenter, and use the attribute as the Dataset in a FeatureReader set to format Google KML.
asadamjad
Participant
  • Participant
  • Jul 13, 2023 9:30 AM UTC
where is the data? columns are empty
asadamjad
Participant
  • Participant
  • Jul 13, 2023 9:33 AM UTC
check the Workspace
asadamjad
Participant
  • Participant
  • Jul 13, 2023 9:35 AM UTC
Output should come like this
geomancer
  • Jul 13, 2023 9:53 AM UTC
These attributes are part of the JSON file, they just need to be exposed in the JSONFragmenter, and renamed to the attribute names you give them.
Unfortunately I cannot open your workspace, as I use an older version of FME.
asadamjad
Participant
  • Participant
  • Jul 13, 2023 10:00 AM UTC
what version you have?
and you can open newer version to please help me out
geomancer
  • Jul 13, 2023 4:05 PM UTC
All the information you need is present, and can be extracted using only a few transformers. I am doing my best to help you to get there. But I cannot solve it for you, I can only try to point you in the right direction.
As far as I can see, you rename attribute 'id' to 'stormid', and 'name' stays 'name'.
'advnum' is present in several attributes, it is not clear which one you are trying to use. What attributes you rename to 'popupinfo' and 'snippet' is unclear.
P.S. I cannot install a new version, as I am on a computer of my employer.
