Removing labels from points in Google Earth
  • Feb 12, 2022 5:29 AM UTC
  • 1596 views
I'm looking to export point locations from FME as a .kml file and I want to remove the labels. I don't think there's an option to turn off labels for points, but you should be able to set the opacity to 0 (I've done this many times before in Google Earth). However, in FME, after I've exposed the kml_label_opacity attribute and set it to 0, the label will still appear when I open the exported .kml file. What am I doing wrong here?
danilo_fme
Forum|alt.badge.img+58
  • Feb 12, 2022 8:21 PM UTC
Hi @virgil_robinson​
Have you tried to use the transformer KMLPropertySetter?
If you want to share your data and/or the prints.
Thanks in Advance,
Danilo
Hi @danilo_fme​
Actually after researching some more I realized I can use the KMLStyler and set label opacity to 0. Can't believe I missed this!
Cheers
danilo_fme
  • Feb 13, 2022 12:27 AM UTC
Thanks @virgil_robinson​ your feedback.
