RegEx to clean up data
  • Dec 17, 2020 2:17 PM UTC
  • 122 views
fmenco
I have a CSV file with attributedata that's structured kind of like this:
apple man woman 1234-567\\1
apple man woman 1234-567\\1B
apple man woman 1234-567\\12
apple man woman 1234-567 child
890.1234-567
apple A3 1234-567
I'm only interested in the 1234-567 number sequence, since this is an ID I need to match further along. The rest of the attribute data can be deleted. The number sequence seems to always have 4 numbers before the hyphen and 3 numbers after. The hyphen isn't essential and can be removed. The number are the most important
How do I go about it? Do I need a stringreplacer or more than one?
I tried this with stringreplacer, mode= regular expression, text to change set to: (?<!\\\\)[0-9]+
But what do I fill in at replacement text? If I fill in a regular expressions in that field, it returns the regular expression...!
I'm using fme desktop 2019
Best answer by ebygomm
Easier to use a stringsearcher, and search for the regex. If will then end up in the match attribute
\d{4}\-\d{3}
Forum|alt.badge.img+54
  • Dec 17, 2020 2:21 PM UTC
\d{4}\-\d{3}
gio
Forum|alt.badge.img+15
  • Dec 18, 2020 9:40 AM UTC
@fmenco​
Stringreplacer is more direct:
regex replace
to search: .*(\\d{4}\\-\\d{3}).*
to replace : \\1
