Random grid selection
  • Nov 5, 2020 2:59 PM UTC
  • 107 views
Hello!
I need to randomly select 7 grids from the grid net including condition that selected grids cannot be self-intersecting and cannot overlap each other. See image below.
How to approach it in the most efficient way?
FME_grid
Best answer by ebygomm
And because looping blocking transformers are so horrible to work with an alternative solution using a spatial relator and some python
Capture
import fme
import fmeobjects
import random
class chooseSquares(object):
    def __init__(self):
        #create blank list
        self.mylist=[]
    def input(self,feature):
        #build list containing feature, id and relationships
        id = feature.getAttribute('_count')
        touches = feature.getAttribute('_relationships{}._count')
        self.mylist.append((feature,id,touches))
    def close(self):
        for x in range(0,7):
            #shuffle list
            random.shuffle(self.mylist)
            #choose grid from first feature inlist
            newfeature = self.mylist[0][0]
            #get features that interact
            exclude = self.mylist[0][2]
            #remove from list any features that intersect chosen gridsquare
            self.mylist = [(f,i,r) for f,i,r in self.mylist if str(i) not in exclude]
            #outputchosengridsquare
            self.pyoutput(newfeature)
Forum|alt.badge.img+63
Use a Sampler to randomly grab one tile, then a SpatialFilter to select all tiles not touching that randomly selected tile. Then use that result set as the input for the next iteration, and so on.
Screenshot 2020-11-05 at 16.15.05I've done 2 iterations here, you can simply copy & paste the rest, or try and do it through looping in a custom transformer.
Forum|alt.badge.img+54
  • Nov 5, 2020 3:35 PM UTC
Looping transformers in FME are fairly horrible to work with when you've got blocking transformers, but it can be done. This is more or less the same workflow as @redgeographics within the transformer but just handles the looping
Capture
  • Nov 5, 2020 4:37 PM UTC
Capture
import fme
import fmeobjects
import random
    def __init__(self):
        #create blank list
        self.mylist=[]
    def close(self):
            #shuffle list
  • Nov 6, 2020 4:43 PM UTC
Thanks for providing all the suggestions! it worked smoothly!
