questions relates to Mapnikrasterizer transformer ,i would like to have the output from this transformer without any scaling as original .input is polygon with lines over it .
  • Nov 23, 2021 8:46 AM UTC
  • 86 views
spiderman
Forum|alt.badge.img+7
i am using Mapnikrasterizer transformer ,i have input polygon and some lines over it .
i would like to keep the output of this transformer without any scaling (without any compressing )as original input .which parameters should i choose at this transformer to do this work ?
as info :i am wiriting the output in excel file .
but i found it looks not great when i use scaling ,it seems to me that it compress the input and looks not good in excel file . so i would like to have another solution
Thanks for help
FME 2018
Forum|alt.badge.img+63
Do you mean the output image size?
spiderman
  • Nov 25, 2021 2:09 PM UTC
i have tried alot to resize but it does not work with me
ri would like to resize the image output ,how could i achieve it ,thanks for help
In the MapnikRasterizer you can set the output resolution in pixels or in ground units, whichever you prefer.
