Question relates to Neighbor Finder
  • Apr 19, 2023 3:48 PM UTC
  • 79 views
gogopotter90
Forum|alt.badge.img+14
Hello ,
i have question relates to neighbor finder .
i have two different data of lines as input of neighbor finder .
lines A
lines B
my parameter : no. to find (keep empty ) without value so as possible
and distance 1 meter .
my target to find which lines from lines A close to lines B within distance 1 meter .
i have got the expected output with id .
But does it possible to find ,which part exactly of lines that has distance 1 meter from other lines and save geometries with id for each part of lines .
thanks in advance
fme 2021
daveatsafe
Forum|alt.badge.img+24
  • Apr 19, 2023 5:46 PM UTC
Hi @gogopotter90​,
If you use a Bufferer to buffer the lines by 1m 0.5m, then send the resulting polygons to an AreaOnAreaOverlayer, the output polygons with overlaps > 1 will give you the areas where the distance is 1m or less.
If you want to find a distance of exactly 1m, use a GeometryCoercer on the buffer polygons to convert them to lines, then use a LineOnLineOverlayer and look for overlaps > 1 on the output.
gogopotter90
  • Apr 20, 2023 2:51 AM UTC
Hi @gogopotter90​,
Thanks a lot ,I will do ur idea .
