Processing JSON output with Fragmenter/Extractor
  • Feb 17, 2023 5:12 PM UTC
  • 51 views
Hello,
I am currently trying to process an output from the JSONformatter that has the below structure:
name_1:"value_1",
name_2:"value_2",
name_3:"value_3", etc.
The output I want to achieve is a feature set as per the below:
name_1 name_2 (as columns)
value_1 value_2 (as values)
I am able to achieve it to an extent using the JSONFragmenter, but this seems to work only for 1 feature (i.e. name_1). I have tried to use the "+" as explained in the documentation but this instead produces a second row, rather than a 2nd column.
May I ask for your advice please?
Thank you,
George
danilo_fme
Forum|alt.badge.img+58
  • Feb 18, 2023 12:24 AM UTC
Hi @georgefloros​
Please, could you share your data?
