Problem with transformer AttributeDecompressor
  • Nov 30, 2016 2:10 PM UTC
  • 82 views
danilo_fme
Forum|alt.badge.img+58
Hello Team.
I have a first Workspace that create a json file after i compressed my Attribute.
When i read the json created on first workspace and try to descompresse , i receive this message: attribute could not be decompressed.
What is wrong?
Attached my templates files.
Best answer by david_r
I suspect the JSON writer automatically forces the compressed binary value into its hexadecimal representation when writing the output JSON file. Then the AttributeDecompressor gets confused because it expects a binary value rather than a hexadecimal string. You can fix it by inserting a BinaryDecorder before the AttributeDecompressor:
  • Nov 30, 2016 2:49 PM UTC
danilo_fme
  • Nov 30, 2016 3:35 PM UTC
Hello @david_r, your suggestion was perfect!!! Really the attribute is works with the tranformer BinaryDecoder.
Thanks your help.
Danilo de Lima
