PowerShell in FME Server
  • October 28, 2022
  • 474 views
deanhowell
Forum|alt.badge.img+23
I have a PowerShell script that copies files from a network drive to a SharePoint site. I can get the script to run manually on the FME Server Server using both my user credentials and the FME Server Service user but when I wrap it into a 'System Caller' it runs but does nothing.
The workbench runs in FME Server calling the following in the System Caller
imageC:\\Windows\\System32\\WindowsPowerShell\\v1.0\\powershell.exe
"D:\\TMR\\SaferSpeeds\\copyToSharePoint.ps1"
My guess is it is some sort of permission issue but not sure where to start.
Any ideas?
nielsgerrits
Forum|alt.badge.img+55
By no means an expert, but I did something similar in the past. What worked for me was:
powershell -executionpolicy bypass "& ""C:\temp\script.ps1"""
But you have to study yourself why this works, as I don't remember.
deanhowell
  • October 31, 2022
Thanks. Still not working for me but will continue to investigate :)
Dean, did you ever resolve this issue. I have a similar issue and can't get to the bottom of it.
