Possible bug in FME 2017 RC on OS/X
Hello, please see https://knowledge.safe.com/questions/40453/invalid-scale-reduction-specified-error-when-openi.html?
Best answer by fmelizard
PR 76123 has been filed. Another customer also experienced this problem and discovered a temporary solution:
1. Open /Library/FME/2017.0/Reproject/LocalCoordSysDefs.fme in any text editor
2. Find the definition for Calgary_3TM_WGS_1984_W114 (~Line 264)
3. Change the SCL_RED value from 0.999900 to 1
4. Save the file and try opening FME Desktop again
Rylan from Safe has added to the question
fmelizard
Forum|alt.badge.img+17
  • February 23, 2017
Hi @david_r. Thank you for catching this, I will look for a potential case and request someone from Safe responds. Thanks!
fmelizard
  • February 23, 2017
rylanatsafe
Forum|alt.badge.img+13
  • February 27, 2017
This issue has been resolved for FME Desktop 2017.0 Build 17257 and Newer.
