populate cell from the value in the cell above
  • Mar 25, 2021 12:53 PM UTC
  • 188 views
I am working with a feature class and I have got some empty cells that share the same Structure ID, I want to fill the missing Archetype value from a value in the above row.
logic can also be created using an index column such as :
it looks simple but I have already spent hours figuring this out but couldn't find the solution. Capture1Please check the data attached to this post.
Thanks in advance
H
Best answer by ebygomm
Thanks @ebygomm​
I have tried this method but i am having issues with creating the correct logic, would you be able to help me create a logic based on my data
Thanks
This logic should work
Test if Archtype has a value, if it does, do nothing (<No Action>). Otherwise, use the Archtype value from the record above (feature[-1].Archetype)
Capture
Forum|alt.badge.img+54
  • Mar 25, 2021 2:39 PM UTC
The answer here might help you figure this out
https://community.safe.com/s/question/0D54Q00008WIfv8SAD/create-a-column-with-values-from-another-column
If not I can provide a more detailed answer based on your sample data
Thanks @ebygomm​
Thanks
  • Mar 25, 2021 5:57 PM UTC
Thanks @ebygomm​
Thanks
Capture
Thanks @ebygomm​
Thanks
@ebygomm​
Sorry for the late reply.
This logic worked like a charm.
Many Thanks
