parquet snappy
  • Mar 15, 2021 2:58 PM UTC
  • 153 views
Hi, I have a data in snappy.parquet format
Does this package: https://docs.safe.com/fme/2019.2/html/FME_Desktop_Documentation/FME_ReadersWriters/safe-labs.parquet.parquet/safe-labs.parquet.parquet.htm
open snappy.parquet format?
Right now I have error like into txt file.
FME see that, but cant read it.
Best answer by mark2atsafe
I haven't tried that hub version, but I managed to get FME to read a file with the built-in reader in 2021. I'm just checking if the two are related. Perhaps it's just a case of removing the hub version and using the built-in one instead.
@lukaszmarciniak​ FME 2021.0 added support for a Parquet Reader/Writer and it does support Snappy compression.
mark2atsafe
Forum|alt.badge.img+59
  • Mar 15, 2021 8:13 PM UTC
@lukaszmarciniak​ Possibly 'timestamp' is a reserved word that the new FME 2021 reader isn't quoting correctly
Hi all, exactly, when I removed the package - everything works fine!
