OSG Reader: No valid or supported geometry read from input file
  • Jan 12, 2022 3:26 AM UTC
  • 125 views
charry
Forum|alt.badge.img+5
FME API version of module 'NULL' matches current internal version (3.8 20210302)
Loaded module 'LogCount_func' from file 'D:\\FME2021\\plugins/LogCount_func.dll'
FME API version of module 'LogCount_func' matches current internal version (3.8 20210302)
Reading...
InputStream::readImage(): Unable to find a plugin for png
InputStream::readObject(): Unsupported wrapper class
InputStream: Failed to read from stream. At osg::PagedLOD osg::Geode osg::Geometry
OSG Reader: Closing reader
Translation FAILED with 2 error(s) and 0 warning(s) (0 feature(s) output)
FME Session Duration: 0.4 seconds. (CPU: 0.0s user, 0.2s system)
END - ProcessID: 12332, peak process memory usage: 49892 kB, current process memory usage: 49892 kB
Program Terminating
Translation FAILED.
mark2atsafe
Forum|alt.badge.img+59
I think this is a question you could send directly to the support team. See safe.com/support - it may be that only a developer could tell us why no data is read.
