Name of transformer to change the co ordinate system of a WFS and then name of reader to connect it up to ArcGIS Online
  • Sep 19, 2023 8:20 PM UTC
  • 43 views
I have a viewer with layers in ETRS89 and want to add a WFS layer in ED50. I need to convert the co ordinate system in the cloud before it reaches ArcGIS Online so that everything is in ETRS89. What writer and transformer should I use? Is there a relevant tutorial (name please!)
daveatsafe
Forum|alt.badge.img+24
  • Sep 19, 2023 8:29 PM UTC
Hi @willowfield​,
FME offers you several transformers that can reproject the data for you. The Reprojector is probably the simplest to use, but if you are an ArcGIS user, you may prefer the EsriReprojector, which uses the same coordinate system names as ArcGIS.
