Mvt tile read error
  • Jun 6, 2022 2:49 PM UTC
  • 107 views
When running a Data Inspector to read a mvt tile ,I got Error message like this "No geometry mapping entry found for 'wkb_geometry_collection' in metafile 'C:\\Program Files\\FME\\metafile\\MVT.fmf'. Please visit http://www.safe.com/support
No geometry mapping entry found for '%0' in metafile '%1'. Please visit http://www.safe.com/support
Failed to specify the feature index as constraints on the reader
I tried to use QGIS ,it works fine.
Best answer by daraghatsafe
Hi @lasx​ thank you for providing your file so we can test it out. I tried to read in the file using FME Desktop 2021.2.5.0 Build 21816 and I ran into the same error that you experienced. I also tried reading the file in using FME Desktop 2022.1 Build 22582 and I was able to successfully read the file in and inspect it.
What version of FME are you using? Would you be able to test on 2022.1?
daraghatsafe
  • Jun 6, 2022 4:56 PM UTC
Thanks for you reply . I tested on 2022.1,it works!
