Missing LIDAR_FME.dll in plugins
  • Jun 28, 2022 9:11 PM UTC
  • 124 views
Getting an error when running a translation from LAS to LAZ format.
Could not load module 'C:\\Program Files\\FME\\plugins/LIDAR_FME.dll' : 'The specified module could not be found'
Don't think it affects the output. Just wondering if it needs to be fixed?
FME(R) 2022.0.0.1 (20220505 - Build 22339 - WIN64
danminneyatsaf
Forum|alt.badge.img+13
Hi @qlddrones​ thanks for bringing this to our attention. This message in the log was exposed in FME 2022 and later. As you noted, the message doesn't affect the output as FME is still able to find the correct library, regardless of the message that appears in the log.
I've submitted a bug report to the developers. The tracking number is FMEENGINE-74065.
We will update you here if a fix is released.
Thanks!
