Missing features FME DGN reader
  • Feb 4, 2022 3:32 PM UTC
  • 5 replies
  • 150 views
wheeler1
I have a dgn file which when I read into FME loses a line and I cannot figure out why. When I view the file in Bentley View I see the following:-BentleyViewIn FME :-
FME
Would anybody have any suggestions as to why this may be? I appreciate that the line is a BSpline Curve, which can cause problems, but others come through OK. Any parameter you may know of that I can change to allow the features to be read?
I have attached a clip of the dgn in case someone would like to replicate the problem.
Many thanks for any words of wisdom 😀
  • Feb 4, 2022 4:30 PM UTC
Be aware that FME does not support 100% of all the object types that can occur in a dgn, that goes in particular for 3D objects. Examples of dgn objects that cannot be handled by FME include point strings (type 22) and certain types of 3D solids and 3D surfaces.
Have a look at this page: https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_ReadersWriters/igds/Feature_Representation.htm
If you compare this list with the Bentley documentation (https://communities.bentley.com/products/microstation/w/microstation__wiki/8855/element-numbers-and-types), you will notice that some IGDS element types simply aren't mentioned in the FME documentation, and therefore aren't supported by FME.
Take a close look at the FME log for hints or warnings about ignored objects.
wheeler1
  • Feb 11, 2022 12:04 PM UTC
Thanks very much for your response David. I will look into it
arnold_bijlsma
Forum|alt.badge.img+16
@wheeler1​ : Did you ever get an answer to this? Looks like I have a very similar problem of curved surfaces in a DGN not getting read properly.
  • Nov 29, 2023 8:53 AM UTC
Try again using FME 2023.2 (available as beta, will be released in a week from now) or later, it seems the geometry support for 3D DGN objects has been extended.
arnold_bijlsma
I have tried FME 2023.2, and whilst it is better than 2023.1, it still skips certain features or only shows the linear structure rather than the curved solids.
(Also the translation log of the DGN reader shows many messages about AutoCAD and DWG. I didn't know these two formats were related)
