Merging several CSV files with different Schema
  • Nov 23, 2020 1:37 PM UTC
  • 259 views
gerard
Participant
I have a FME 2019 Desktop workflow that reads three CSV files and write all input data (points) to only one FeatureClass in the output fileGeodatabase.
Every CSV file has a different schema, i.e.: every CSV file has several fields in common but most of them are different.
This is the workflow:csv2gdbEvery month I will have to run this workflow with a different set of CSV files with probably will have different schema than this ones, and also could be more than three CSV files.
So, how can I read automatically the schema of CSV files ? Thank you !
gerard
Participant
  • Participant
  • Nov 24, 2020 1:33 PM UTC
I have found the appropiate combination of parameters, and the answer is very simple:
  1. The CSV reader select all *.csv files in a directory, with Single Merged Feature Type and Automatic read of Schema
  2. The File Geodb writer, has to define FeatureClass or Table Definition as Automatic .... (not Dynamic, as I thought)
workflow2
Now I have the output structure that i need but I have to solve the problem of generate points form CSV input data. If I define ReaderSchema as Manual I can assign several fields to (x,y,z) coordinates, but I have defined that option Automatic ....
One possible solution is do it in 2 steps:
  1. Generate a merged CSV with the combined structure of fields,
  2. Generate a GDB with this merged CSV reading manually the Schema
Any idea for solving that in one step ? Thank you
gerard
Participant
  • Participant
  • Nov 24, 2020 2:33 PM UTC
workflow2
Ok, VertexCreator is the solution.
