Make ArcGIS OAuth Redirect URIs Easier to Discover and Configure in FME Form and particular in Flow
  • Jun 29, 2026 5:57 AM UTC
  • 70 views
j.botterill
Forum|alt.badge.img+69
In >2026 to connect to AGOL or Portal enterprise from FME, we utilise the “unified” Esri ArcGIS Enterprise OAuth (Template)(safe.esri-agol) web service   ARCGISFEATURESERVICES
Working with Esri ArcGIS Feature Services in FME – FME Support Center
The article perhaps fails to mention how to handle the web service Loopback Interface Redirect or Proxy Redirect Strategy, as the Embedded Browser is deprecated in FME Form 2025.2
The arcgis registered application needs to have http://localhost as redirect URI
What about FME Flow redirect URI?
My suggestion is in Connections & Parameters - FME Flow for any given safe.esri.agol
newest Esri web service in Flow >26
It needs a default Redirect URI of “ self “?
natalieatsafe
Forum|alt.badge.img+12
Hi ​@j.botterill , thanks for your post. I have put in a request to add a new subsection to our Working with Feature Services in FME Form article, so that it’s a bit easier to find the information you’ve requested.
The new subsection will highlight:
Let us know if that sounds like it would suffice here!
j.botterill
  • Jul 16, 2026 12:39 AM UTC
Updating how-to-articles to align with the major release changes, such as new oauth redirect strategy with screen shots from your beta / QA testing would be very benefit to those deploying the new versions and to aid those planning out their upgrades
