Loop through FeatureJoiner
  • April 24, 2021
  • 197 views
connecter
Forum|alt.badge.img+10
is it possible to loop through a FeatureJoiner? I created a custom transformer and I activated the setting to allow blocking transformers. My goal is to remove the first 3 rows and the connected IDs in the rows further down.
2 Screenshots (hopefully) help to understand the problem).
Thanks!
loop_2
loop
Best answer by takashi
Hi @connecter​ , if I understand the requirement correctly, I think this workflow does the trick. No need to implement looping.
update-id-list
  • April 26, 2021
update-id-list
connecter
  • April 26, 2021
update-id-list
Thanks @Takashi Iijima​ , cool trick!
