Link attributes of 2 points that are graphically linked by a line
  • Aug 9, 2022 1:46 PM UTC
  • 93 views
arash_hokm
Forum|alt.badge.img+8
PointsI have 2 kind of points that are connected graphically every 2 points with a line. I would like to know how FME can be used to link the attributes of points with associated ones. I am attaching an example for better understanding.
Best answer by gisbradokla
There are likely many solutions to this.
Without seeing any data. I would.
  1. use a guid generator on the line features
  2. use one of either neighborfinder, spatialrelator, pointonlineoverlayer to "associate the points with the lines and get the guid attribute onto the points.
Another method might be to extract the beginning and ending points from the lines with the vertexcreator (instertatindex) 0, and then again for -1 which will get the beginning and ending of each line. Then a point on point overlayer will get the values of the line onto each point. be careful because some (actually most) of the overlayer transformers will creaate points everywhere there is an overlap. like at a T. That is why using the index would be helpful because you only get the beginning vertex and ending vertex.
gisbradokla
Forum|alt.badge.img+27
  • Aug 9, 2022 7:46 PM UTC
arash_hokm
  • Aug 10, 2022 8:10 AM UTC
Many Thanx :)
