Limit/shorten the logging in Command Prompt window when executing FME with command line
  • Aug 22, 2022 10:04 AM UTC
  • 14 replies
  • 235 views
axcel.fme
Forum|alt.badge.img+3
Hi there, I'm sorry if I have overlooked the answer to a similar question in this forum. I could not find such a question...
When executing the FME workflow from the command line, there is a entry for every 500 features that the reader has processed. With some large data to process, this can amount to many lines in the command prompt window. I cannot scroll up infinitely in this window and it's also not easy to scroll these vast amount of lines if you need to see some other logged output before the FME was started.
Is there a way to configure the logging output so that it will not produce this vast amount of lines?
A simple solution could be specifying the logging interval (e.g. increase 500 to 5000) .
As an ideal scenario, the Reader-logging is by default using only one line in the CMD window and is always overwriting itself until the next process in the FME workbench starts when normal logging is to resume with starting on a new line every time.
hkingsbury
Forum|alt.badge.img+73
  • Aug 22, 2022 7:59 PM UTC
I was wondering if you'd be able to specify the workbench logging level in the CMD call. But looking at the documentation it seems you can't
https://docs.safe.com/fme/2020.0/html/FME_CommandLine/
However there is the option to not log to standard output and instead log to a file. Would that work?
axcel.fme
  • Aug 23, 2022 6:49 AM UTC
Hello and thanks for the reply.
Logging to a file is not really what I'm after. It would require to open every single log file to check for any errors that might have occured during the FME process.
I have a lengthy overall process that runs as a batch script over night with several calls of the FME and in the morning one simply want to check if there is any errors. That's why the logging in the window actually comes quite handy.
I hope Safe Software takes up this point as an improvement suggestion to their incredible software. Configuring the logging output in the CMD window would be a big help and improvement!
axcel.fme
  • Aug 23, 2022 8:14 AM UTC
As an interim-solution, how can I suppress the logging in the CMD window completely? I checked the "save log to file" option in the FME Options but I still get the output in CMD window. Is there any way to disable this completely somehow?
  • Aug 23, 2022 4:54 PM UTC
As a workaround, you can increase the vertical screen buffer of the command line window, which will let you scroll back much further: https://superuser.com/a/378323
hkingsbury
  • Aug 23, 2022 7:52 PM UTC
In that documentation it says to disable logging use the following:
[LOG_STANDARDOUT <YES|NO>]
   If YES, the session will log to standard output as the translation executes.
axcel.fme
  • Aug 24, 2022 1:34 PM UTC
Thanks for this tip. This is indeed helpful.
I still think that hundreds or even thousand lines of the reader is not really helpful and makes it hard to get an overview of what was going on. I hope Safe Software comes up with something better.
hkingsbury
  • Aug 24, 2022 8:29 PM UTC
Had another look at this. I had originally thought that the Log Message filter only filters in FME Workbench and doesn't effect the workspace (.fmw).
However, looking at it, it does change the workspace as well as being a persistant setting in workbench.image
So, in other words, if you set your required logging level in workbench, save your workspace with that logging, it should then be reflected when you run the workspace via the CLI
FMW with all logging enabled:
FME_DEBUG MAPPING_FILE BADNEWS UNGROUPED UNCORRELATED DUMP_SCHEMA XSD_VERBOSE HTTP_DEBUG FTP_DEBUG FME_DEBUG STASH
LOG_FILTER_MASK -1
FMW with only 'Log Errors'
LOG_FILTER_MASK -20
axcel.fme
  • Aug 26, 2022 7:45 AM UTC
Hi there and thanks for looking into this.
I disabled several logging and left on only "Log Errors" in the FME Workbench 2022.1 under
Tools > FME Options > Translation > Log Message Filter
as described. I then added a transformer and deleted it afterwards so that I can save the file again. When I then make the same command line call I still get all the lines from the Reader in the CMD window.
Is there any setting that I missed...?
  • Aug 29, 2022 7:47 AM UTC
Unless you set LOG_STANDARDOUT=Yes, the command line window output won't include the FME log, which is why limiting the FME log contents won't change anything.
If you want to suppress all the output sent to STDOUT on the command line, try redirecting the output to null, e.g.
fme my_workspace.fmw > null
  • Aug 29, 2022 7:57 AM UTC
They did, it's called FME Server ;-)
axcel.fme
  • Aug 30, 2022 1:52 PM UTC
Please excuse my ignorance but where do I need to place this
LOG_STANDARDOUT=Yes
exactly? I tried to include it into the command line calling the FME with its input and output parameters but I got an error.
  • Aug 30, 2022 2:28 PM UTC
LOG_STANDARDOUT=Yes
Excellent question. When I looked into the documentation it seems this option is not generally available, in fact. Should've checked it before I mentioned it!
axcel.fme
  • Aug 30, 2022 2:49 PM UTC
Aha. Wouldn't this be an excellent feature for Safe Software to implement into their next release...? Would be wonderful!
  • Aug 30, 2022 3:04 PM UTC
Consider entering your idea here: https://community.safe.com/s/bridea/acideasULT__brIdea__c/00B4Q00000AWlEVUA1
