Limit on LAS files that can be converted
  • Apr 29, 2021 11:35 AM UTC
  • 97 views
Dear All.
I have made an absolut simple workbench with LAS reader to a Recap writer. Nothing fancy.
But it seems to have a limit of an amount of files that I can read and write. right now the limit is about 70 files in write.
I have searched and asked around at the office, but cant get an answer.
I have 100gb available space and plenty of memory, so that is not the issue.
Attached is the script.
Hope there is a solution, since there are about 1.000 files that needs to be converted which will result in about 10.000 files written.
kailinatsafe
Forum|alt.badge.img+24
Hello @mrmlaursen​ , there should be no limit on number of files on reading or writing. Took a look at your workspace, nothing obviously alarming there. I decided to see if I could repro this and I got the following error: "ReCap Writer: Failed to convert LAS files to RCS scan files. The following error occurred: ..." . If you would want to try by dividing up your translation in some way?
I think one potential solution would be to change the writer to use Dataset Fanout instead of Feature Type Fanout. Right now you are setting Feature Type Fanout to:
@Value(fme_basename)-@Value(_split_value)
If you instead set Dataset Fanout to:
 and Feature Type Fanout to:
the translation may work, but would have a different directory structure than you do now.
Let me know if this works for you! Here to help, Kailin.
  • Apr 30, 2021 9:17 AM UTC
Hi, yes I started that way with the simplest of LAS reader and Recap writer but is also have the limit at about 70-100 files.
See attached. But still issues.
Forum|alt.badge.img+54
  • Apr 30, 2021 9:26 AM UTC
Can you write a parent workspace and run one file through at a time with a workspace runner?
kailinatsafe
@ebygomm​ I feel like that may work, with Wait For Job To Complete parameter set to Yes maybe.
