Keep all points within the same distance from each other in chaine
  • Sep 12, 2022 6:29 PM UTC
  • 69 views
boubcher
Forum|alt.badge.img+11
Hello There
we have a set of point features we want to filter the point that has the same distance +- 5m to each other
as You can see in the picture
we should keep 1 ,3.5, and 7 since there are at +- 5m distance and should delete 2 ,4 and 6
If we go with a neighborhood finder with a max length 5m will work but point 2 and 4 are also located at a 5m distance,
the goal is to keep only one set of points the green or the blue
danilo_fme
Forum|alt.badge.img+58
  • Sep 14, 2022 1:33 PM UTC
Hi @boubcher​
Pelase, could you share your data, for me do some test?
Thanks in Advance,
Danilo
boubcher
  • Sep 14, 2022 3:09 PM UTC
Hi @boubcher​
Thanks in Advance,
Danilo
@danilo_fme​
Sure
Please not the point are aligned 100% but to goal is to keep points that are at the same distance to each other forming a chain
danilo_fme
  • Sep 20, 2022 10:48 AM UTC
@danilo_fme​
Sure
Awesome. I'll make some tests, thanks!
