Is this PythonCaller documentation incorrect?
  • Jan 27, 2021 11:56 AM UTC
  • 73 views
btl
Forum|alt.badge.img+12
I tried running the Class Interface example on this page:
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Transformers/Transformers/pythoncaller.htm
But the code as written, (after correcting the indentation) gives me the same area for each polygon.
To get the expected result I have to remove the 3rd & 4th from last lines (and re-correct the indents) i.e.:
import fmeobjects
class FeatureProcessor(object):
    def __init__(self):
        self.featureList = []
        self.totalArea = 0.0
    def input(self,feature):
        self.featureList.append(feature)
        self.totalArea += feature.getGeometry().getArea()
        feature.setAttribute("total_area", self.totalArea)
        self.pyoutput(feature)
Was this written for an earlier version of Python, or is it an error?  I'm not good enough at Python to know why the original script didn't work.
Best answer by ebygomm
The indentation is incorrect in the example, and the changes you've made have removed the def close statement. It should be as follows
import fmeobjects
    def __init__(self):
    def close(self):
        for feature in self.featureList:
Forum|alt.badge.img+54
  • Jan 27, 2021 12:05 PM UTC
import fmeobjects
    def __init__(self):
    def close(self):
btl
  • Jan 27, 2021 12:23 PM UTC
I see. My amendment actually gives the cumulative area, not the area of each polygon.
