Is there a way to check the status of a running FME job through a PowerShell script?
  • Dec 15, 2023 8:04 PM UTC
  • 74 views
vkishoregit
Participant
Is there a way to check the status of a FME job through a powershell script?
joepk
Forum|alt.badge.img+22
  • Dec 18, 2023 11:31 AM UTC
You could write certain files at certain 'checkpoints' of your FME scripts and search for said files using PowerShell. If you only need to know if the job is still running you could maybe do something with reading the Task Manager
