Is there a way to access on FME-server stored DB connections through FME workbench?
  • Dec 3, 2020 11:45 AM UTC
  • 90 views
edgarrunnman
It would be awsom if there would be a sync function to uppdate Database connections and get DB connections stored on FME server to lokal env.
12
  • Dec 3, 2020 12:59 PM UTC
When you publish a workspace using a database or web connection, you will be asked if you want to publish or update the server connection as well.
edgarrunnman
Thanks for tips @david_r​
but that only upplouds my connection.
  • i want to be able to change parameters on DB connections on server and have it sync to my desktop
  • i want to be able to share connections with other users and have it sync to their machines
  • i want to be able to use connections used by other users when i download workspace from FME server
Shared folder for .data and public Key files is not either what i'm after. It's a sync between users but not a sync to FME server... say i want to change password to connection. i have to do it on at least two places
  • Dec 3, 2020 1:21 PM UTC
I understand, unfortunately I do not know of any such possibility.
