Is there a method to read the data from ArcGis to Fme desktop
  • Sep 7, 2022 1:42 PM UTC
  • 5 replies
  • 72 views
gogopotter90
Forum|alt.badge.img+14
Could I read the data from arc Gis with Fme desktop professional?
dustin
Forum|alt.badge.img+36
  • Sep 7, 2022 1:43 PM UTC
Yes, several ArcGIS formats available to read into FME (file GDB, SDE, etc).
gogopotter90
  • Sep 7, 2022 4:07 PM UTC
but to read ,I think it require Fme Esri but I have Fme desktop ?
And other question , Does it possible to read by oracle spatial data format ?
could u write me the method to connect Fme desktop with arc gis
rahulsharma
Forum|alt.badge.img+12
Hi @gogopotter90​
There are 2 requirements in order to work correctly with ArcGIS and FME applications.
  1. Required ArcGIS License types for FME Geodatabase formats
  2. FME license requirement for Esri formats (most likely an FME Esri Edition license will work).
FME_License_Req_Esri
But since you mention that you might need to read and write Oracle Spatial database, I would recommend using a Database Edition license
To get you started here are a few articles that can help.
Tutorial: Getting Started with Geodatabase
How to use an Esri Template Geodatabase
Tutorial: Getting Started with Oracle
Working with GIS Data and FME
gogopotter90
  • Sep 8, 2022 12:28 AM UTC
Thanks , i will read what u meantioned .
i have read an article that use ArcGIS Feature services at Fme workbench .will be enough to read the data from Arcgis ?
any tips regarding it ?
fme desktop professional
rahulsharma
Yes, If you want to read the following formats, FME Desktop Professional Edition licenses is good enough for all the following datasets
Esri ArcGIS Online Feature Service
Esri ArcGIS Portal Feature Service
Esri ArcGIS Server Feature Service
A good starting point for this format are below
Tutorial: Getting Started with ArcGIS Online and Portal
