Is it possible to convert or export an ArcGIS Online/Portal web map into a pdf file in FME?
aguan
Forum|alt.badge.img+11
I would consider do this using ArcGIS python API, but wondering if FME can handle this, which would save me a lot of time and effort.
hkingsbury
Forum|alt.badge.img+55
  • February 1, 2021
Its likely you can do it with the ExportMap endpoint in the REST API.
https://developers.arcgis.com/rest/services-reference/export-map.htm
Easiest way to check this would be to monitoring you network activity (using the developer console in Chrome/Firefox) during a manual export from agol
aguan
  • February 2, 2021
@hkingsbury, thanks. Will take a look in this.
