Is it possible to add the coordinates from the coordinate extractor transformer to a writer?
  • Nov 21, 2020 4:52 PM UTC
  • 76 views
lily
Forum|alt.badge.img+14
Is it possible to add the coordinates from the coordinate extractor transformer to a writer? Like example from coordinate extractor column _indices{}.x (64 bit real) into a shapefile with column x.
I tried changing data type from double, float, char... but the line connecting the transformer to writer simply will not connect to each other.
Best answer by jlbaker2779
{} indicates a list. The coordinate exactor has an option for Specify Coordinate. That will extract the coordinate to an attribute.
  • Nov 21, 2020 8:33 PM UTC
lily
  • Nov 22, 2020 6:48 AM UTC
@jlbaker2779​  Thank you so much!!! Now it writes XY into my writer!
bwn
Forum|alt.badge.img+26
  • Nov 23, 2020 1:33 AM UTC
Note that the default Coordinate is the Coordinate of Point{0}, ie. The Start Point. Whilst this is fine for Point Geometries, it may not be the "X, Y" wanted for a Polyline or Polygon.
If instead the Centre X, Y is desired, use CenterPointExtractor instead.
lily
  • Nov 23, 2020 1:07 PM UTC
@bwn​ ​ Thank you!! I have both point file and polygon file. so I will try your suggestion too!
