Is it more adequate to use ListExploder to read from a .dat file and populate a specefic field or a line? Image inserted shows the file and i want to read in line # 17 (Power Flow Status: ....etc)
  • Oct 17, 2022 8:55 PM UTC
  • 101 views
danilo_fme
Forum|alt.badge.img+58
  • Oct 18, 2022 3:09 PM UTC
Hi @khireddinehiche​ maybe is necessary to split by lines first with AttributeSplitter.
@khireddinehiche​ I would agree with @danilo_fme​ . Use the Text File reader to read your data, AttributeSplitter to split on ":" . Then...
Use AttributeCreator and for the New Attribute column select "Attribute Value" (not Select Attribute) from the pull down menu for the list{0}. This will rename your list{0} to Power Flow Status. For the Attribute Value column, use list{1}
@Mark Stoakes​ and @danilo_fme​  thanks for you help, i was able to get it to work!
Now i get a different issue, where using the ListExploder is giving me this error and i'm not sure what it is!
@khireddinehiche​ We probably need to see the whole message and also the feature dump above to be able to interpret that error message
