Inconsistent behaviour featuremerger missing
  • Sep 30, 2022 12:48 PM UTC
  • 92 views
romar
Forum|alt.badge.img+3
During one of my projects I noticed in my counts that I am missing records.
Project Image
As you can see 16k entries enter the requester eand only 13k exit via either port. This is connected to missing keys entering into the requestor
I know that I can solve this using a nullattributemapper to change missing into null, or by setting reject null and missing keys to 'Yes' (non-default setting). However the fact that this is largely invisible has me worried.
I have also concluded that this behaviour is not consistent. The below workspace has a test setup testing for the behaviour with simple input data. All 4 cases behave as expected. Unless I missed something, I believe this is a bug. If you can confirm, deny or reproduce, it would be highly appreciated :).
tomfriedl
Forum|alt.badge.img+14
  • Sep 30, 2022 1:03 PM UTC
Set the parameter "Reject Null and Missing Keys" to "Yes".
By the way: Very good Workbench to test
romar
  • Sep 30, 2022 1:07 PM UTC
Thank you for your answer and the compliment:).
I know of multiple ways of how to fix the issue, once spotted.
It is the 'stealth' and inconsistent behaviour of this issue that I am concerned about.
tomfriedl
  • Sep 30, 2022 2:41 PM UTC
You are right. Better is "Reject Null and Missing Keys" set default to "Yes". Much better the features going out to "UnmergedRequestor".
