In FME 2017 format "Esri Legacy ArcSDE" available but in FME 2020 i am not able to see Esri Legacy ArcSDE.
  • Sep 23, 2020 3:19 PM UTC
  • 5 replies
  • 43 views
rajibtechlabs
oscard
Forum|alt.badge.img+23
  • Sep 23, 2020 3:25 PM UTC
It is no longer supported. The Esri Enterprise Geodatabase (SDE) doesn't work for you?
rajibtechlabs
  • Sep 23, 2020 3:36 PM UTC
Thanks Oscard ,
Then how i will connect to ArcGIs SQL Database through FME 2020. I am using ArcGIS 10.6
hkingsbury
Forum|alt.badge.img+73
  • Sep 23, 2020 8:23 PM UTC
Thanks Oscard ,
That will work fine, I'm using 2020.1 to connect to SDE 10.2
oscard
  • Sep 24, 2020 5:38 AM UTC
Thanks Oscard ,
The Reader/Writer I have posted should work for you. Give it a go and if you have any issue configuring it let us know.
