IFC to IFC
  • Aug 23, 2022 9:09 AM UTC
  • 11 replies
  • 267 views
magi
Hello
I have 4 different IFC models and wish to merge them into one.
Could you please help me ?
thanks in advance.
Best answer by evieatsafe
WriterWB allmissing attribute tableall attribute tablehello thank yo so much for your reponse , i appreciate . Here the concern is loosing attribute values. I was able to aort out the colour as the IFC file was incorrect and when i choose as 2x3 it all went well. The problem that still need help and support is MISSING attributes . In the WBench until AttributeExposer_3 i am able to see the Attributes as desired, BUT when i write them to WRITER it looses or does not contain the Attributes that i am after or looking for.
@magi​ I suggest using the "SchemaScanner" because you are writing to a dynamic writer.
Dynamic writers need a dynamic schema that the SchemaScanner creates from your features and attributes. You need to connect both the <Schema> port as well as the Output port to the writer for it to read the schema. Also make sure to specify the Schema Definition Name is the same as the name that is created in the SchemaScanner. image
magi
they all have the same schema and need to merge / append them into one file without losing geometry and its attribute
 ALSO when merging and opening it in Naviswork the object loses its original colour , so if you have some clue or idea or suggestion ON how preserve or keep the original properties intact .
evieatsafe
Forum|alt.badge.img+28
  • Aug 23, 2022 7:03 PM UTC
Hi @magi​ thanks for your question, having not seen your data or workspace - have you tried using the Aggregator to combine your models? You can have it set to "Merge Incoming Attributes" instead of "Drop Incoming Attributes" to keep all of your attributes.
Not sure what is happening with loosing the colour of your model; however, you can set the appearance manually in FME with the AppearanceSetter alongside the AppearanceStyler.
Hope this helps! Evie
magi
  • Aug 25, 2022 10:10 AM UTC
magi
  • Aug 25, 2022 10:11 AM UTC
@Evie Lapalme​ please let me know if could provide solution for this
evieatsafe
  • Aug 29, 2022 9:04 PM UTC
Hi @magi​ I'm happy to hear that some of your issues have been resolved. What format are you writing out to? What type of writer definition do you have (eg. Automatic, Manual, Dynamic)?
Depending on the attributes you want to be written out, you may have to rename them before writing after you have exposed them. This is common with FME attributes eg. fme_geometry. Other obstacles in writing attributes are that not all writing formats will accept spaces or extra characters such as : or - and I would suggest renaming these attributes with CamelCase (especially if you are writing to a Shapefile or Geodatabase). Also make sure that you are connecting all of your attributes if the connections don't populate automatically.
imageIf you are using a dynamic writer, make sure to use a SchemaScanner to populate the schema for the dynamic writer. Check out this article on Dynamic Workflows for more information.
magi
  • Sep 1, 2022 9:09 AM UTC
See just BEFORE and AFTER WRTIER...loossing this attributes
BEFORE:
imageAFTER :
ORIGINAL INPUT READER
image +
evieatsafe
  • Sep 1, 2022 4:53 PM UTC
I see you have a dynamic writer, have you tried using the SchemaScanner like I suggested previously?
magi
  • Sep 6, 2022 9:09 AM UTC
I didnt see any transformer named "SchemaScanner"
evieatsafe
  • Sep 6, 2022 5:00 PM UTC
Hi @magi​ the documentation on the SchemaScanner can be found here, hope this helps!
You can add any transformer by typing freely on the canvas to quick add it, or select the "Transformer" icon on the top ribbon next to readers and writers to search for the transformer of your choice.image
magi
  • Sep 8, 2022 2:45 PM UTC
Hi i am aware about this but what is the tranformer name specifically that u suggest ?
evieatsafe
  • Sep 8, 2022 5:24 PM UTC
