Identify if lines are perpendicular and running in parallel
  • Dec 13, 2023 8:37 PM UTC
  • 166 views
galigis
Forum|alt.badge.img+22
Hi All,
I'm working on a workflow to identify if lines are perpendicular and running in parallel. Below screenshots shows what I'm trying to achieve:
  • Line A and B should run in parallel and have the same Y
  • Line A should have the X for start/end to be perpendicular
  • Line B should have the X for start/end to be perpendicular
I have put this workflow together and create a QA tool to flag the issues (not perpendicular and not parallel) but can't find the workaround:
image.pngAny idea how to get this done?
Thanks 🙂
DanAtSafe
Forum|alt.badge.img+23
  • Dec 13, 2023 10:57 PM UTC
Hi @galigis​ If the two parallel lines should have the same lengths and position that they could form a rectangle - then aggregate them and replace with a BoundingBoxReplacer (2d Oriented), then chop the box into 2-point line segments and compare those against the original lines with a ChangeDetector.
