I want to reproject dwg files from MTM Zone 10 NAD27 to MTM Zone 10 NAD83 CSRS using EsriReprojector by geographic transformation. Although I downloaded and extarct FME Reprojection Grid Add-on., and put them in fme directory it could not find them.
  • Mar 22, 2023 9:29 PM UTC
  • 126 views
gis.analyst
Forum|alt.badge.img+4
Also, I put the .gtf file in the customTransformations folder. It could not find either.
(I use ArcGIS Interoperability extension and the directory that I used is "C:\\Program Files (x86)\\Esri\\Data Interoperability (x86)\\reproject\\EsriPEGridData\\customTransformations" for .gtf
and C:\\Program Files (x86)\\Esri\\Data Interoperability (x86)\\reproject\\EsriPEGridData\\ntv2\\canada for.GSB)
daveatsafe
Forum|alt.badge.img+24
  • Mar 23, 2023 10:09 PM UTC
HI @gis.analyst​,
Please clear the Coordinate System settings on the reader and writer. The reprojection is being handled by the EsriReprojector, and we want to avoid adding a possible implicit reprojection into the process.
Would you mind sharing the .gtf file?
gis.analyst
  • Mar 27, 2023 1:28 PM UTC
Hi Dave
Thanks for your answer
I did it but it does not work
the error is smae as before (it could not find gsb)
I attached the .gtf file and GSB
