I published the workspace from FME Desktop to FME Server but it doesn't downloaded the required python kafka dependencies in the packages of FME Server Path
  • Feb 15, 2023 3:57 PM UTC
  • 114 views
319	2023-2-14 17:20:38 | Python Exception <ModuleNotFoundError>: No module named 'fmepy_kafka'
320 2023-2-14 17:20:38 | PythonFactory failed to load python symbol `fmepy_kafka.KafkaConnector'
321 2023-2-14 17:20:38 | Factory proxy not initialized
322 2023-2-14 17:20:38 | f_209 (PythonFactory): PythonFactory failed to process feature
323 2023-2-14 17:20:38 | An error has occurred. Check the logfile above for details
The missing packages path in FME Server is  'Resources > Engine > Packages > 22782-linux-x64 > python > safe.kafka > fmepy_kafka'
merlinegeorge
Hello,
This should be a helpful article- https://community.safe.com/s/article/FME-Server-and-Packages-Python-Exception-ModuleNotFoundError
Is this error specific to only the Kafka connector in FME Server?
Could you please provide the build and version of FME Server and FME Desktop used ?
Hello Merline
I tried everythin of the article, except to download manually the .fpkg
I will check it
No, the error is first for the kafka connector but if I add manually the kafka connector .py, then it ask for other .py classes and packages
FME Server 2022.2.2 Build 22782
FME Desktop 2022.2.2.0 (20230106 - Build 22782 - WIN64)
