I need to convert Revit to SPLK/I3S to be used in ArcGIS Pro. I used the following simple transformers in FME 2024.0.0 but once I import it to Pro the location is not correct and all attributes get disappear. Can someone help me please
  • Jan 5, 2024 5:16 PM UTC
  • 141 views
myadegaryiutac
Forum|alt.badge.img+11
This is the original uniquevalue Data with the number of existing features.
1140 Metadata.Worksets
203 Metadata.ViewInformation
182 Metadata.FamilyInformation
105 Metadata.MaterialInformation
20 Electrical.CableTrays
16 Electrical.CableTrayFittings
8 Metadata.PhaseFilters
7 Metadata.LevelInformation
6 Metadata.StyleInformation
5 Metadata.LinkInformation
4 Metadata.PhaseGraphicOverrides
2 Metadata.ProjectPhases
2 SitePoints
1 Architectural.Railings
1 Metadata.FileInformation
in Tester transformer I used (Architectural.Railings / Electrical.CableTrayFittings / Electrical.CableTrays)
The Original coordiante system was : XY-MM
I used CoordinateSystemSetter and set CRSM.MTM-10 and then chang it to EPSG:3857
For the writer I used I3S with i3s_3d_object Geometry
daveatsafe
Forum|alt.badge.img+24
  • Jan 5, 2024 11:41 PM UTC
Hi @myadegaryiutac​,
The FeatureReader is the same as a regular reader, and should need only a single trigger feature to read the Revit file. The output features from the FeatureReader also don't appear to be connected to the I3S output, just the Initiator features from the initial reader.
In the Revit reader parameters, please try changing Revit Coordinate System to Read to 'Georeferenced'. This will read the georeferenced coordinate system if the Revit file has been georeferenced. If the coordinate system on the features is still XY-MM, then the Revit file has not been georeferenced, and you may need to use the Offsetter and Scaler transformers to adjust it to CRSM.MTM-10.
