I'm trying to extract spatial data from Oracle to an ESRI file geo database in ireland 1965 tm 29902 projection but it writes out 29903.
  • Feb 10, 2021 4:04 PM UTC
  • 87 views
 Even when I specify the projection in the writer it writes out to ireland 1965 29903.
Any ideas how I fix this?
thanks in advance
Rhona
jovitaatsafe
Forum|alt.badge.img+11
Hi @rhona​,
Check out Dave's answer to FME cannot write Irish National Grid TM65 coordinate system to Esri formats for the full explanation and workaround if you would like to write out to EPSG 29903. In summary, FME maps the same definitions for 29902 and 29903 as we follow Ordnance Survey Ireland's lead as the originating authority on the projections. Dave goes it into a lot better detail though so please take a look at the link above.
  • Feb 11, 2021 7:58 AM UTC
Hi @rhona​,
Thank you :) I appreciate your help, it sorts my problem.... and he worded his question so much better than me
jovitaatsafe
You're very welcome! Glad to be able to help (:
