I have installed FME 2021-2 64bit outside of C:\\Drive\\Program Files ie: D:\\ Drive. Is this installation different to, if I were to install it on C:\\Programs Files folder on a 64bit Win2016 Server?
  • November 11, 2021
  • 5 replies
  • 23 views
pushpa
Forum|alt.badge.img+9
The reason I am asking is, I am running out of memory when running my FME script.
|FATAL |Insufficient memory available -- error code was 2 - please read the FME Help section 'Adjusting Memory Resources' for workarounds.
  • November 12, 2021
The installation location should have no bearing on memory.
Concerning running out of memory, have a look here: https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_QuickTranslator/Workbench/memory_resources_adjusting.htm
pushpa
  • November 12, 2021
thanks, I cannot set 3Gb switch as my server is 64bit ,I already purged temporary files and FME_TEMP setup on D:\\FME_TEMP away from C:\\drive as I have very limited space on it. I can run this script on my Desktop without any issues but I cannot run on Windows2016 server as it gets memory issue.
Kind Regards,
Pushpa
Forum|alt.badge.img+50
How much memory do you have? And what are you trying to do with your FME workspace?
mark2atsafe
Forum|alt.badge.img+45
  • November 12, 2021
Kind Regards,
Pushpa
This might be a question to contact the support team about (safe.com/support) - if you can include the workspace and log file they might be able to spot where - and why - the problem occurs. Include both the desktop log and the server log, so that they can compare the two.
pushpa
  • November 16, 2021
Kind Regards,
Pushpa
Thanks Mark. I will contact Safe Support.
Kind Regards,
Pushpa
