I get this warnings in FME Flow and I have no idea how to fix them. Can somebody explain to me, what these 2 error messages mean and how to fix them?
  • October 26, 2023
  • 120 views
Excel Reader: Found named range '_xlnm._FilterDatabase' on sheet 'Datenfelder'. This is a Microsoft Excel internal name so FME will not show it as a sheet. If you wish to read this named range, please rename it
Excel Reader: Unable to recalculate formulas and refresh pivot tables for Excel file 'Failed to open workbook. Ensure this is a valid Excel file'. %1
merlinegeorge
Forum|alt.badge.img+5
Hello,
Are you able to successfully run the workspace in FME Form of the same version ? Does the job run result in a failure or does it still successfully run?
Regarding the 2nd error- This could be a known issue.
Would you be able to submit a case with the Excel file, the workspace, the full FME Server log and Desktop log?
